Hi - I'm on my first custom WC build.
Fans - I get AF vs SP etc. It's the connection to the mobo that concerns me - would really appreciate any observations for the below plan (ASUS x99 deluxe).
5 radiator fans - into a pwm splitter with the splitter powered by the psu. this is plugged straight into the cpu header so as the mobo controls the loop.
Case fans - plugged into the mobo case fan sockets
Pump - plugged into the secondary cpu header which I understand is not pwm.
theory being -the mobo controls the pwm rad fans, I control the case fans and the pump is constant with mobo alarm set if it fails to start. As there is a gpu in the loop, I would just lower the cpu temp for fan speed.
Am I on the right track, and can anyone suggest a suitable pwm splitter.
thanks.
thanks.
