Well it wasn't too long ago that I posted https://forums.overclockers.co.uk/showthread.php?p=28957729#post28957729
Talking about how I could get 4.9GHZ at 1.32V stable. Well I've definitely jinxed myself!!
Over the past few weeks I've had a lot of system crashes. BF4 crashes constantly. I didnt pay it much attention and thought it was compatibility issue with windows 10 pro. Anyway got tired of the constant crashes so I changed back to Windows 7 ultimate!
Recently got a ASUS ROG GTZ980TI Maxtrix Platinum, so when BF4 carshed in windows 7 I put it down to early drivers. Anyway as the days progressed windows started crashing a lot, decided to return everything back to stock...and bam! 100% stable no crashes gaming for hours on end. To cut a long story short I'm struggling to get 4.8GHZ at 1.35vcore, prime95 loads but then crashes after 1 min. OCCT keeps reporting different core errors. I managed to do a 20 min prime95 at 4.7GHZ at 1.35v but OCT at the same settings reports errors in cores.
In short I think my CPU has degreded so fast! Am actually surprised to say the least; I knew it would eventually degrade but never this quick! Generally do Intel degrade quick? This 4790k is my first intel, I've always ran AMD, from the days of Athlon 1600+.
My last CPU was a AMD 1090T and that was overclocked to 4.5GHZ with insane Voltage (can't exactly remember...i think around 1.46v) and that never degraded during all the time I had it, which was for 3 years. I've sold that setup to a close friend of mine who's still running it with no issues. Also I'd like to add that was air cooled. (Awsome cpu in all honesty).
Back to my 4790K, my temps were all within acceptable limits, only once did it reach thermal throttling and that was me pushing the hell out of it at 1.4V after taking my H110i off and re-fitting it and didnt apply new paste. As soon as i saw it reach 100 i stopped the test, so wasnt at those temp for more than a second. Went out and got the H110iGTX the same day and temps never reached 70 or higher under full stress, I never went up to 1.4V again.
Did the thermal throttling damage it maybe?
I'm pretty naffed off that this cpu had degraded this quickly in all honesty. I have contacted silicon lottery and they said as soon as they get 5GHZ 4790K in stock they will email me so I can snatch one up. However now am thinking will that also degrade as quick? Is it the architecture of the cpu that doesn't hold up overclocking too well? or was I just very unlucky? I mean 1.32v was not high at all!
