but then by overclocking it, it will use more power again?Was looking for a lower TDP cpu
The unlocked multi won't give you any more headroom, however the 6600k is a better bin so it might do 100-200mhz more. Tbh its all down the the silicon lottery, a bad 6600k will be slow than a good 6400.Is it even worth buying a "K" version at all? I was pretty much set on buying a 6600K in the new year but now i'm uncertain. Do the 6400 and 6600K have similar max ceilings when overclocking or is there more head room with the 6600K with the unlocked multiplier?
I hope Asus follow with mini itx i have gone off Asrock
I don't see why people on many forums are getting excited about the Core i3 6100. So you need an £80 to £100 motherboard to overclock a £95 CPU with another £15 to £20 for the cooler. At this point you might as well get a Core i5 6400 and a cheaper motherboard which will cost around the same - at least from what I gather the Core i5 6400 seems a better bet,since the saving over the Core i5 6600K looks huge.
So,IMHO is the Core i5 6400 which looks like the star of the show TBH!!
I am offering Overclockers bundles with both these CPU so the end user can make there own choice.
6100 is still great value for sure.
