Elaborate?
It's kernel level so I guess if there is a kernel that supports it it would do the same. I'm running elementalX on the N6 but it doesn't have this feature. Maybe the newest version has?
Edit, just checked and it's only for the 6p, elementalX hasn't implemented it on the N6. It would be handy indeed.
Supports the N6 and 6p?Franco has added it to his FKapp now & kernel.
Supports the 6p too also.
I've read theres a bug that doesn't allow the WiFi radio too sleep if its on 5GHz leading too greater battery drain.
Cheapest place to get this on PAYG?
Check your network first. I know the 6P won't work on Three so there may be others.
