- 4 Nov 2015
- Kilcock
So I have an issue with an all-new build. I have a dual screen setup, 2 x Dell U2412M and have them connected to my Palit GTX 970 Jetstream through a DVI and Display port.
The DVI on a single display works fine but whenever I introduce the display port connection, whether on both or one - doesn't matter which or both of the two I choose - there are intermittent restarting issues. Some days it is okay and others it won't startup until I disconnect (one or all) the DP cables. It won't get to the windows loading screen before the whole thing shuts down and starts up again.
Other specs; GA Z97P-D3 (F6 Bios), i5 4690k, 8gb Kingston fury 1866mhz.
I've checked around and there is apparently a bios issue but I have the most recent F6 and from what I found it is related to older versions. I would like to avoid sending the card back anywhere even if there are workaround methods.
Any help or thoughts appreciated.
