- 9 Apr 2012
If I take out a phone contract with O2, say, does my credit score reduce? I suppose I am asking if they do a hard or soft credit check.
I ask because when I was declined by Vodafone not even a soft search showed on my credit file. Absolutely nothing showed up. Very odd.
[TW]Fox;28979209 said:A mobile phone contract is unlikely to adversely affect your credit file, if anything it probably enhances it. It isn't a significant amount of money but it does demonstrate you can pay regular bills on time and develops your credit history.
Is there anyway we can check are own credit score ?
Essentially I'm using O2 Refresh so I'm going to pay off the handset loan cost right away and then cancel the airtime as per their terms and conditions.
I assume my credit file isn't going to change as essentially I'm never using the credit.
Your credit file shows how much debt you have, how often you pay it, how much you pay, and how well you can keep up with your debts.I assume my credit file isn't going to change as essentially I'm never using the credit.
Yes. They do the hard check and if you take out a contract it reduces a bit more.
[TW]Fox;28979273 said:I've no idea what the numbers involved are but this seems an odd way of getting a handset. Surely there is a cheaper and less hassle way?
It's the cheapest way to get an S6. You can get one for £259.99 this way rather than £359 from Argos so a £100 saving.
[TW]Fox;28979710 said:Surely you also have to buy out of the airtime contract to cancel it, adding more cost.
Guess you're doing the S6 Refresh deal going around HUKD right now, I have done a similar thing with my Note 3 a year ago and can't say I noticed my credit score dropping, I had Check My File at the time and numbers seemed to have stayed the same.
