migrate my reverse to win7 files off my SSD
5 Oct 2012
I am 95% sure I will keep my windows 10 installation. Had a small hiccup with avast, but change from avast to AVG and it's sorted the problems for me.
Currently disk cleanup reports there is about 40GB of space being used by the Previous windows installations.
It's sitting on my SSD primary hard drive. Is there a way to move those files onto a HDD which isn't limited in space?
I just googled and learnt that the installation is stored in windows.old folder
Can I move that folder onto a different drive and then move it back to the primary if I ever need it. Or will the move later the configuration and make it unusable?
doesn't the windows.old folder contain the rollback data to revert back to previous installation?
I do have backups of documents but reinstalling the 40+ apps I use alogng with the configurations is what I hate most. So I prefer to keep a full system backup.
Yep. You should be able to just move it and restore it should you need it (don't hold me to that though - I've not seen anyone try it, but it ought to work), but you only have 30 days to revert to your previous OS before the license permanently transfers to Windows 10.
It's stupid in a way, but given how long it took Microsoft to move people from XP to Vista & 7 I can understand.
Anyway, you've no worries from my point of view - Windows 10 is just as solid as 7 & 8 was for me. :)
Windows 10 has a few hiccups still (Start menu sometimes not working etc...) but overall it is a good experience thus far. :)
I've never seen that outside of a corporate set up.
There are some well documented problems with the start menu when it comes sysprepping and copying a user profile and trying to establish a default layout (to the point where clicking on the Start button gives no response), but like I say that has been limited to trying to dictate the layout to users, and I found it easy enough to solve through GPO anyway.
