Even more Crossfire questions.
23 Apr 2010
West Sussex
1. Does Fallout 4 work properly with Crossfire yet?
2. What games specifically do not support Crossfire that you have found?
Thanks.
Elite Dangerous, FC4 took about 4 months for a proper profile.:(
CrossFire can be brute forced most of the time with various results going from good to sometimes rubbish usage or having to disable msaa.
Don't know if your going to find it any more acceptable than SLi tbph.
Thanks.
2. Off the top of my head, Just Cause 3 (hopefully to be fixed, fingers crossed!), Batman Arkham Knight, Sniper Elite 3 in Mantle (DX11 works fine).
Ack, so JC3 doesn't support it? that bends :( Mind you to be fair I am still very much into FO4 and haven't even bought it yet.
I just wanted a boost for FO4 for the moment because I'm now on the "Explore the map and uncover every location" and there are certain areas of the map that makes my Fury X crap itself at 4k.
Thing is, I can't seem to find any solid info on the net as to whether Crossfire even works with FO4.
Aye - Just Cause 3 was the only game I was looking forward to this year (LOVED JC2!) and it does suck that it doesn't support Crossfire. Unfortunately, it doesn't SLI either (http://www.dsogaming.com/news/just-cause-3-engine-is-incompatible-with-all-multi-gpu-solutions/) so it looks like it's an issue that the developers will need to fix rather than AMD or Nvidia. Really hoping it's not like Batman AK where the developers eventually decided it was too difficult/non-cost-effective to support multi-GPU and just decide not to. :(
Game still runs fine on my setup currently, but at 5760x1080 and with all settings except AA on their highest, I am only getting 30-40FPS most of the time. Doesn't stop me enjoying the game, but really would be happier if the other GPU was chipping in a few FPS to get it more up towards 60FPS most of the time.
So Fallout 4 is all working and OK now then?
I'm planning a second playthrough where I side with the Institute too.
Batman Askham Knight won't support crossfire or sli the devs have said they won't be releasing support for it.
I don't blame them they take so long to get the game playable just now you wouldn't want more issues to be added in.
That's no issue given I can't stand comic books/super heroes. I've not even played the first Batman for more than ten minutes tbh.
I think I am decided on another Fury X, now that I have modded my case to take it :) I was going to go Nano but would rather two X.
