Hey all,
so I've now ordered all the parts I think i'll need for my first loop, and while waiting for everything to be delivered have got round to thinking about how to go about putting it all together and after some pointers, advice and a sanity check on anything ive missed or ordered wrong, so bear with me
In my head I have a rough idea of the order and position of everything and hopefully have covered all the items i'm likely to need, parts are as follows:-
enthoo evolv atx case
5820k
x99 krait edition
16gb hyper X predator 2400mhz
ref r9 290 (from old machine)
120gb & 500gb Samsung evo 850 ssd's (from old machine)
corsair RM650 (from old machine) ordered braided cables from cable mods (excellent service from them btw)
water cooling parts
ek xres 140 revo d5 pwm
ek r9 290 acetal+nickel gpu block
ek supremacy evo x99 cpu block
360mm coolgate g2 rad
240mm magicool g2 slim rad
mayhems ultra clear 10/16 tubing
alpha cool 16/10 fittings 2x 45°, 4x 90° 6x compression
for a drain point 1x Y 45°, ball valve, double nipple and 3/8" barb
ocuk 120mm 3 fan bundle, 2x corsair sp120 led 1x corsair af140 led
1litre mayhems pastel ice white
and finally some thermal grizzly paste and coollaboratory cleaning set
the plan will be for the 360 rad to sit in the front of the case and the 240 to go in the top with the components in the following order:-
360 - pump - cpu - 240 - gpu - 360 with hopefully enough space to get the drain point in the bottom of the case
so given the above is there anything I've missed?
as to the build itself I do have a few questions:-
1) I take its good practice to flush the rads, can I hook them up to a tap or do I need to fill it with DI water and give it a shake?
2) Given that the cpu and mobo are new should I build everything out of the case 1st using my current air cooler off my 2500k to make sure it boots and install the os and drivers while i'm at it?
3) regarding the os, I take it just need to win 10 home and not the pro version
4) when I fill the loop do I take I just take the pug off the top of the res and fill by that?
any comments, questions and advise would be greatly appreciated as it'd be nice for this to go smoothly as possible for change
regards
fritzo
5820k
x99 krait edition
water cooling parts
regards
fritzo
