- 12 Jun 2008
the cost and hassle involved will likely mean its easier to buy another case while you're out there and take components in well padded hold luggage.
I might consider that if the shipping costs turn out to be astronomical. But will definitely check on tower (and other component) prices beforehand. Money is tight, so I want to avoid paying for parts if I can.
Sell it and buy a laptop, you're never going to have time to use your PC once the baby arrives anyway!
Well from experience
Got my entire PC in the cargo luggage on the plain
You should take the hard drives with you as they might not survive
The case was dropped on a corner
The case is a solid steel beast ,,old server case``
Aftermath:
Cpu cooler a 92mm fan &tower was tied with rope towards all sides
The CPU came out of the socket: no damage
And the case got crushed a hammer has restored its side door removal ability
SO: remove CPU cooler
Get a box and well wrap the case
Remove the magnetic storage if data is important
If graphic card is big and heavy advice to remove as well
For power supply compatibility with 110V check on the label
Or tell us make and model
Depends where you are in Canada - there are a few PC specialists plus stuff like tigerdirect (if they still exist) but given how big the country is and how remote some parts are that can very much be a problem.
What make and model is your PSU? If you're not sure, it should have a sticker on the side of it. Hopefully that sticker will show it's input voltage (usually "AC Input: 115-240V" or similar). If not, the manufacturers website will give you the details, or post up the make and model here and I'm sure someone will be able to find it for you and at least put your mind to rest on that.![]()
I'd be amazed if the PSU doesn't just work on 110v automatically. Just check the label on the back, it will likely say 110-240v and you're fine.
I got my PC shipped back from Hong Kong in a container, just wrapped it in a few layers of cardboard and it got packed in a box same as everything else. I just had a stock cooler in it, if I had a monster one I would have removed it to prevent damaging the mobo, but otherwise, no problems.
Righto,
A mate of mine moved from the UK to Canada when Bizarre Creations folded a few years ago.
All his stuff was packed up into a shipping container and sent over.
Things he learnt about PC transport.
A CPU cooler can snap off the mounts, land on the graphics cards and break everything in the case.
His advice is....
Remove and box up:- CPU cooler, gfx card, psu, etc etc.
Basically everything in the case that isnt the motherboard, cpu or ram. Leave those mounted in the case.
Personally if it's air cooled, then I'd either go with taking everything out.
Or fill it up with the air bags which you get you OCUK packages filled with to prevent things shifting around.
NCIX and TigerDirect are a couple of companies to look at when your out there for PC stuff, I watch LinusTechTips who is from Canada and he used to work for NCIX, and thats how I know of them... Your best chances are removing everything that with a sudden bang, could break off, such as GPU, CPU Cooler, things like that and carry hard drives with you as they are also sensitive to shocks..
Just had a look at shipping prices, 20KG's to Canada is going to be £62. Better than I thought to be honest.
Doubt each screen is going to be more than 12KG's making that £48 each, that is a little harder to swallow.
I did it the other way around. Shipped PC from canada to uk.
Stuck it all in a big box, towels and clothes around it and shipped it home. The mobo broke but everything else survived (inc monitor). Took about 4 weeks though.
What do you use the machine for? If it isn't work related I wouldn't bother taking it. Having a kid takes all your free time![]()
