- 11 Mar 2013
Will Pascal bring DP 1.3? Going beyond 4k will bring graphics to a whole new level
I meant coming this next gen
I doubt Nvidia going to support DP 1.3 or anything ever above DP 1.2
Because that means they will have to support Freesync by default on hardware level.
What will they do then?
I meant coming this next gen![]()
They will stick to DP 1.2 or else......![]()
I would think they have to use DP 1.3 if they want 8K?
Adaptive Sync is optional in the 1.3 spec.
You should check your facts before donning the ol' tinfoil hat.
Q: Is VESA’s new AdaptiveSync supported?
A: Yes. AdaptiveSync was first supported by DisplayPort 1.2a, and it is already supported in some available products. This is also branded as “Free-Sync” from AMD, which is based on VESA’s AdaptiveSync Standard.
remains an optional part of the specification
DisplayPort Active-Sync remains an optional part of the specification
Was optional standard to support for 1.2, as it was 1.2a,
supported does not mean required, don't look at the FAQ look at the actual spec or an article written by someone that has
http://www.extremetech.com/extreme/...d-with-displayport-1-4a-allows-for-8k-scaling
http://www.anandtech.com/show/8533/...rt-13-standard-50-more-bandwidth-new-features
it wasn't even optional in 1.2 as 1.2a was the first revision that contained it
Hardware wise, it will be there in the DP port, Nvidia can choose not to implement it on their drivers.
You're in a minority and it's not just about you and those with G-sync monitors.why would I want them to add cost to the GPU when I already have Gsync?
or are AMD lying when they say their GPU's contain additional hardware needed to support freesync?
I doubt they will support it but it's besides the point, Once we (IF WE) eventually get TV's with freesync Nvidia will have to make a decision on whether to support it or have there market size reduced, I imagine they'll continue to milk people with G-sync for as long as possible before they do support it though.
So, in other words, Nvidia chooses NOT to support Adaptive Sync on DP 1.3, so the rest have to pay the Gsync tax.
You do realise that this statement is the sort of ammo in the arsenal, any marketing department wants against a competitor company?
And how you feel as a consumer, having NV limiting you the options because they want to push their own expensive product, even if the implementation at hardware level is there, and they have to switch it via drivers?
No, Nvidia will stay behind the curve.
they painted themselves into a corner with Gsync.
I guess a 1440p HDR 144hz screen isnt what they want you to buy.![]()
