GFX card upgrade advice
7 Jan 2016
Hello folks. I need to upgrade a gfx card that can run the following game:
http://www.systemrequirementslab.com/cyri/requirements/skylanders-spyros-adventure/11225/?p=a
I have already spent a long time looking at cards similar to those recommended in the link, however the recommended cards are upto 10 years old and not available new or only available used, which I am dubious about.
So basically I would appreciate any suggestions of a suitable new pci-e card, as cheaply as possible. It's not for a hardcore gamer, just for someone who wants to run the above game.
It's a windows 7 pc, btw.
Thanks for reading.
Honestly, you'd have to look at used. Cheapest new you could use is something like a r7 250 or a gtx 750, though if he is using an AMD APU he will have similar IGP power as the 250 tho.
Used, look for a gtx 660 or a radeon 7850/7870.
Thanks for the reply.
As regards used, I suppose it's a difficult question, but is there much risk involved in buying used gfx cards?
Do they deteriorate much with use?
It really depends on who you buy it from, if you get it from a reliable seller (based on rep), you should be fine.
