** More Maximus Muchness! **
OcUK Systems
OcUK Staff
16 Nov 2007
Stoke-on-Trent
COMING VERY SOON featuring RGB
Asus Maximus VIII Formula Intel Z170 (Socket 1151) DDR4 ATX Motherboard @ £274.99 inc VAT
- LGA1151 socket for 6th-gen Intel® Core™ desktop processors.
- Dual DDR4 3733 (OC) support
- Best gaming cooling – CrossChill EK for both air and liquid cooling
- Best gaming lighting – Three-way RGB illumination, Aura 4-pin RGB-strip header & lighting control
- Best gaming audio – Reinvented SupremeFX 2015 with intuitive Sonic Studio II
- Best gaming performance – 5-Way Optimization with Auto-Tuning, second-gen T-Topology, and OC-friendly design
- Best gaming networking – Best-in-class Intel® Gigabit Ethernet, LANGuard and GameFirst technologies
- Best gaming protection – ROG Amor plus carefully-selected premium components for maximum durability
- Best gaming connectivity - 2x2 802.11ac MU-MIMO Wi-Fi, U.2 and M.2, plus Intel-powered USB 3.1 Type A+C
- ROG gives you more – More gaming-oriented utilities, all free!
Specification:
CPU
Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
Chipset
Intel Z170
Memory
4 x DIMM, Max. 64GB, DDR4 3733(O.C.)/3600(O.C.)/3500(O.C.)/3466(O.C.)/3400(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory, Dual Channel Memory Architecture
Onboard Graphics Outputs
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz
- Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
Maximum shared memory of 512 MB
Multi-GPU Support
Supports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
PCI Slots 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, gray)
1 x PCIe 3.0/2.0 x16 (x4 mode, black)
3 x PCIe 2.0 x1 (black)
Storage
Intel® Z170 chipset :
1 x U.2 port, support PCIe 3.0 x4 NVM Express storage
1 x M.2 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode)
6 x SATA 6Gb/s port(s)
2 x SATA Express port,
Support Raid 0, 1, 5, 10
ASMedia® ASM1061 controller
2 x SATA 6Gb/s port(s), black,
USB
8 x USB 3.0 port(s) (4 at mid-board)
4 x USB 2.0 port(s)
Intel® USB 3.1 controller :
2 x USB 3.1 port(s) (2 at back panel, , Type-A + Type-C)
ASMedia® USB 3.0 controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
Audio
ROG SupremeFX 2015 8-Channel High Definition Audio
LAN
Intel® I219V Gigabit LAN
WIFI/Bluetooth Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports MU-MIMO
Bluetooth V4.1
Form Factor
ATX Form Factor - 12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Only £274.99 inc VAT.
ORDER NOW
Asus Maximus VIII Hero Alpha Intel Z170 (Socket 1151) DDR4 ATX Motherboard @ £229.99 inc VAT
World's first Z170 gaming motherboard with integrated RGB headers
- LGA1151 socket for 6th-generation Intel® Core™ desktop processors
- Dual DDR4 3800 (OC) support
- Best gaming connectivity - Aura RGB-strip headers, 2x2 802.11ac MU-MIMO Wi-Fi, U.2 and M.2, plus Intel-powered USB 3.1 controller
- Best gaming performance – 5-Way Optimization with Auto-Tuning, second-generation T-Topology and OC design
- Best gaming networking – Best-in-class Intel Gigabit Ethernet, LANGuard and GameFirst technologies
- Best gaming protection – Carefully-selected premium components to ensure maximum durability
Specification:
CPU
Chipset
Intel® Z170
Memory
4 x DIMM, Max. 64GB, DDR4 3866(O.C.)/3800(O.C.)/3733(O.C.)/3600(O.C.)/3500(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory, dual Channel Memory Architecture
Integrated Graphics Processor- Intel® HD Graphics support
HDMI/DisplayPort 1.2 ports
Multi-GPU Support
Nvidia SLI and AMD 3-way Crossfire
PCI Slots 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, +gray)
1 x PCIe 3.0/2.0 x16 (x4 mode, +black)
3 x PCIe 3.0/2.0 x1
Storage
2 x U.2 port
1 x M.2 Socket 3, with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
Intel® Rapid Storage Technology supports
Supports Intel® Smart Response Technology
USB
6 x USB 3.0 port(s) (2 at back panel, blue, 4 at mid-board)
6 x USB 2.0 port(s) (2 at back panel, , 4 at mid-board)
1 x USB 3.1 port(s) (1 at back panel, black, Type-C)
1 x USB 3.1 port(s) (1 at back panel, red, Type-A)
Audio ROG SupremeFX 2015 8-Channel High Definition Audio
LAN
Intel® I219V, 1 x Gigabit LAN Controller(s)
WIFI/Bluetooth
Bluetooth V4.1
Form Factor 1
Only £229.99 inc VAT.
ORDER NOW
Pastymuncher and a positive comment unheard of!!
Look good to me and a genuine way to customise your rig.
I don't understand why everything looks like the unwanted offspring of a Transformer these days. I'm getting old I swear.
don't mind admitting I'm 43 and think they are damn fine looking mobo's, especially that Maximus. Beauty is in the eye etc...
I think they look great - would have liked some of these features on an X99 board - but hey ho, you cant have everything.
Don't care so much for the RGB, but that stealthy look, covered PCB and rear IO shield give it a clean look. Why is my finger hovering over the Pre-order button :(
I thought the LED lights on my Asus Mobo would look cool
..then I filled the case up and you can't even see the damn things.
