A good DAC for tight(ish) Budget
24 Jan 2014
Chesterfield
I am just in the process of upgrading the sound on my system and i have found that i need an DAC and get rid of my internal soundcard.
I have ditched my active 2.1 speaker system, logitec Z6323 2.1 THX and gone for a passive set of book shelf monitors powered by a mini amp.
Amp: Amptastic
Speakers:Q2020i
Im currently using an internal sound card, the Creative Sound Blaster Z which sounds great through the amp and speakers, but, and its a big but, i am getting electronic noise coming from my pc and i can hear it through my speakers when they are idol. It annoys me.
So, im looking for DAC so there shouldn't be any interference from inside my case. The main purpose of which is to connect my amp to it so it will need to have analogue left and right line out, headphone amp isnt really need as i use my Kingston HyperX Cloud II's
So whats out there that will give the best i can get for money? Budget is around £100 but i may have to go a little higher.
Im running Win 10 pro so has to be compatible with it.
Schiit Modi 2 (£90) is worth a look though if you can stretch to £130 the Schiit Modi 2 Uber offers more inputs and an improved analogue section.
They both look like they tick my boxes, only problem being is I cant seem to find anywhere in the UK that sells them. Importing them from the US makes them a less affordable option.
Schiit is where I'd put my money, but then I've not read up on the rPAC much or indeed listened to it.
I believe electromod is one of the official Schiit stockists?
I've emailed Electromod/Schiit EU as the Electromod site shows the Modi 2 Uber in Stock but the Schiit EU site says out of stock.
I would think the difference in sound quality isn't huge as they both use very good DAC chips and as long as the support circuitry is well implemented a cheap DAC sounds almost as good as an expensive one. That support circuitry is probably going to be a fair bit better with the Schiit as Mike Moffat is an industry leader in digital audio plus the Uber features some filter down tech from the Biftost in it's analogue section.
So while the differences in sound quality will be subtle, they will be there all the same.
Where you will see a difference is in the warranty. The Modi 2 Uber has a warranty with a British company with a very good history of customer service. They will also do repairs (at your expense) on out of warranty equipment, should it fail a few years down the line, which is something a lot of companies won't do. The SMSL is just sold through Amazon by GrandView, who's proper title is "Hong Kong Mint&Jasmine Technology Co.,Limited", so good luck with any warranty there. :D
Ive just found a UK site for the Schiit gear, out of stock.... Arse
Thanks, ill have a look....
Has anyone had any experience with the Audioengine D1 Premium 24-bit DAC or the Optoma NuForce uDAC-3?
I used a uDac2 for about 2 years both as a pre-amp and to run m50 headphones. It was ok but I did get a hum from the speakers when the headphones where plugged in, im not sure how the uDac3 has been improved but personally I would avoid it and go for the Schiit as everyone seems to use that at this price point.
Point well made about the warranty and quality of components.
Did they reply about stock levels?
it seem someone has put some stock on the electromod site they must have found some on the stock take i will ask what is happening though.
Regards
That was at 3:41pm and nothing since so no idea if there's actually stock or not.
You're paying a chunk extra for a headphone amp (and a low powered one at that) which you have said you don't need
Might be worth posting a "Wanted" advert on the Head Fi classifieds. I've managed to get a Modi 2 Uber for £85 delivered.
