So I'm building my backup Mini-ITX rig using a G3258 - I'd like to OC it to 4.5Ghz and run it like that if possible. Obviously, stock cooling won't do for that.
To keep costs low I want to use a budget, but compact, ITX case. So I picked the Silverstone Sugo SST-SG13B. It has a max CPU clearance of 61mm in the specs.
So, looking for the best 60mm CPU cooler that does a good job of cooling at that level of overclock. How about it guys?
