Phanteks have released the widely acclaimed Evolv ATX case in 'Galaxy Silver' It looks stunning in the flesh, and represents a great alternative to the Black & Gunmetal versions that we currently stock. Specification is exactly the same as the current versions in stock, and stock will land hopefully before Xmas, in limited quantities only! Will update once I know a firm ETA.
Phanteks Enthoo Evolv ATX Mid Tower Case - Silver @ £139.99 inc VAT
Addressing the online community’s desire for the ATX verison of the Enthoo EVOLV case, Phanteks have released the new Enthoo EVOLV ATX to the EVOLV series. A premium mid tower chassis with an aluminum exterior with minimalistic design based on the original Enthoo EVOLV. The EVOLV ATX
features the quick release side panel system, innovative top radiator bracket, and the new HDD mounting system.
Like the EVOLV, the EVOLV ATX retains the full 3mm thick aluminum outer panels with the quick release system. The EVOLV ATX features a 4 color changeable power LED. With the EVOLV series ranging from mini ITX to micro ATX, the EVOLV ATX features a large interior to support full ATX systems. Unleash unlimited possibilities with the Enthoo EVOLV ATX.
Features
- Aluminum body (3mm thick)
- Clean interior - Hidden PSU and HDD’s
- Power LED - Changeable to 4 different colors
- Retractable Radiator Bracket - Convenient Installation
- Toolless Sidepanel with swing door
- Side Window to show off your components
- Quick release panels for easy access
- Equipped with 3 x Phanteks PH-F140SP 140mm Fans, PWM Hub, 35mm Cable Management Space and Phanteks Velcro Ties
- 2 x SSD Brackets Included
- 3 x Modular 3.5" HDD Bracket included
- Watercooling ready with Reservoir/Pump Mounts and space for up to 360mm radiators on Top/Front Panel
Specifications
- Dimension: 235 mm x 495 mm x 510 mm (W x H x D) 9.25 in x 19.5 in x 20.1 in
- Form Factor: Midtower
- Colour: Galaxy Silver
- Material(s): Aluminum (3mm), Steel chassis
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side window: Yes
- Expansion slots: 7
- Internal 3.5”: 8x (5x included)
- Internal (dedicated) 2.5”: 3x (2x included)
- Air Cooling Support: Front - 3 x 120mm, 2 x 140mm (2 included) , Top - 3 x 120mm, 2 x 140mm, Rear - 1 x 120mm, 1 x 140mm (1 included)
- Liquid Cooling Support: Front 120mm - Up to 360mm, Top 120mm - Up to 360mm, Rear 120mm - 120mm, Front 140mm - Up to 280mm, Top 140mm - Up to 280mm, Rear 140mm - 140mm
- PH-F140SP Included Fan Spec: Speed (rpm) - 1200 ± 250 rpm,, Max Airflow: 82.1 CFM, Static Pressure - 1.33mm H2O, Acoustical Noise - 19dB
- Graphic card clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- CPU cooler clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in) , 140mm: 48 mm (1.89 in)
- Model: PH-ES515E
- Net Weight: 10.2 kg (22.0 lbs)
- Gross Weight: 11.9 kg (24.3 lbs)
- Package Dimension: 310 mm x 570 mm x 564 mm (WxHxD)
- Warranty: 5 Years
Only £139.99 inc VAT.
ORDER NOW
Features
Specifications
- Side window: Yes
- Model: PH-ES515E
- Warranty: 5 Years
ORDER NOW
