EVGA Reveal New ATX Chassis @ CES 2016
The reason why that case is that big is to have a perfect airflow and cooling in the system. Everything right of the card got removed so nothing is blocking or misleading the airflow while still enough space for radiators is left. Also for the exhaust there is a tunnel left so the hot air gets out of the system right away. What we had also in mind when designing it was that people want to show off with their components and the case gives a perfect view on mobo and grakas.
in my opinion it looks awesome. Will not mind doing a water cooling build in it. plenty of space and design works for me.
any idea when it is coming out and what size/number of radiators it will support?
In another video, an EVGA rep states it should support a 360 up front and a 360 up top.
Yeah I really need to learn how to embed :p Here is link anyway, at around 1 min mark.
wow, i like the look of that!! maybe i need to hold of my new case purchase when i replace my CM690III!
whats UK price please EVGA rep? an whens it out?
Hi All
I can fill you in a little more as I have just returned from the US from CES and then our EVGA Global Sales Meetings...
We will have a range of chassis (6 in total) launching in May/June time. The range would start from around $79 up to the top of the range unit at $299. The higher you go the more features and different materials you will see on the chassis. The case you see however is the basic concept (in terms of air flow) and size. From here a few changes and alterations will be made but nothing major as the feedback was all in all very positive at CES.
The first chassis to launch in May/June should be models at $99, 149 and 199.
I can help with further questions if needed.
Thanks
Ben
