Lumia 640 takes ages to charge?
Man of Honour
5 Apr 2009
Have one of these as a work phone, was on around 30% of so when I got in today at 6.30, put it straight on charge, it's around 80% now.
This is on a 2A capable charger, surely that's slow for some reason?
My Z3 will go from virtually flat to almost full in that sort of time.
Does the Lumia just have some sort of monster battery?
Z3 is quick charge 2. It'll only take an hour or so to fully charge. The lumia won't be quick charge. I don't think. I haven't checked the specs.
It's not quick charge however, that's very slow.
You should have been able to charge it from zero to 100% in that time.
Try using the official charger.
Pretty sure neither are officially QuickCharge compatible.
The official charger is just as slow, hence using the 2A capable one to try and speed things up a bit.
Well increasing the charger capability should give some improvement, the stock charger is only 0.75A, less than 5W, the phone should easily benefit from more. That link even suggests it should charge quicker with a higher wattage charger.
Microsoft are absolutely mental if the phone is only capable of charging at 3.75W, that would be utterly crap
My 640 notifies me when it's not on a 2A charger and charges swiftly when it is, so it sounds like you have an issue, either with the charger, cable or phone.
