Had an issue today, powered on the PC, BIOS flagged up i believe about overclocking settings. I checked everything, temp was all ok etc. Not had any issues with my OC. Quit out of BIOS and then the BIOS went into a boot loop, would not even get to the point that the speaker would beep. The LED would flicker through 36,32 then restart.
Changed the BIOS to the backup one, still the same. Pulled the power, pressed power to drain, pressed, held the bios reset, power in, the same. Pulled power, pressed power button, took out bios battery for 20+ seconds, all back, still the same.
Pulled out a stick of RAM, powered on, got to the BIOS, odd thing was all the BIOS settings were still there. Thought it could be XMP profile, set back to default, saved, started doing the same, pulled RAM put the CPU multi to 44 from 46, saved, started all ok, put the RAM back in, started again, so far all ok.
Odd thing is not been able to boot although ive been running this OC no issue for about a year. Then the BIOS didn't clear. Think i tried the BIOS reset a few times.
For any reference MB is Gigabyte z97 UD5H BK, i5 4690k, TeamGroup Vulcan Red, 4x4GB. H80i.
OC is 4.6Ghz at 1.265v.
Anyone else had anything odd like this?
