Ok so ive changed afew things around and added the Intel i5, is it worth looking at Intel i7? How does the list below look?
- Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail = £205.99
[*]Hydro H60 V2 High Performance Liquid CPU Cooler (CW-9060007-WW) = £59.95
- TUF Z97 Gryphon Armor Edition Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard = £138.99
- Radeon R9 Nitro 390 8192MB GDDR5 PCI-Express Graphics Card with Backplate (11244-01-20G) = £259.99
- Vengeance Pro Silver 16GB (2x8GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY16GX3) = £79.99
- 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) = £62.99
- Caviar Blue 3TB SATA 6Gb/s 64MB Cache HDD - OEM (WD30EZRZ) = £77.99
- RM Series RMi 850 '80+ Gold' 850W Modular Power Supply (CP-9020083-UK) = £127.99
Total Price = £1,013.84
You have a mismatched socket (1150) and cpu (1151)!
That Skylake cpu is not compatible with that Z97 motherboard, you need a socket 1151, some of which can be had for a better bundle price with the 6600k eg. https://www.overclockers.co.uk/giga...-6600k-bundle-20-pounds-saving-bu-021-gi.html
Originally Posted by UTmaniac View Post
That Skylake cpu is not compatible with that Z97 motherboard, you need a socket 1151, some of which can be had for a better bundle price with the 6600k eg. https://www.overclockers.co.uk/gigab...bu-021-gi.html
The issue with the FX8 CPU is that they have much lower IPC than Intel's CPU, and they need all 8 cores fully utilised in order to be on par with 4 cores i5; on any games they doesn't fully utilise all 8 cores, they fall behind Intel i5. So basically on any games that use 4 cores/threads or less, the FX8 would only be having 50% of less of it's full performanceWell I am just going to have to disagree here.
4 cores at this point is not going to be future proof. You'll hopefully be fine playing games released in the next 6 months but after that ..
The issue with the FX8 CPU is that they have much lower IPC than Intel's CPU, and they need all 8 cores fully utilised in order to be on par with 4 cores i5; on any games they doesn't fully utilise all 8 cores, they fall behind Intel i5. So basically on any games that use 4 cores/threads or less, the FX8 would only be having 50% of less of it's full performance![]()
youll be fine.
a modern quad will be good for 3-5 years yet in games.
anything above in enthusiast .
games companies need to sell the new games to people so it has to be able to play on the majority for money to be made.
so a i5 is fine.for many years yet.enjoy.
Yeah I was surprised the price of the 390, I was expecting at least £330.
And yeah I was thinking about the future with regard to my CPU but I guess I could always upgrade to an i7 at some point when the i5 begins to struggle. The i5 fits well in my budget and will allow me to play all games that I got on Steam currently at max settings and smooth fps hopefully, as currently my PC is 7 years old and slowly deteriorating underneath my desk.
And crap yeah Ive just noticed the sockets with the CPU that they aint compatible with the Motherboard!!
I could either go with
The bundle provided by UTmaniac
ORRRRRR
- Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - Retail
Any views on getting on the i7 instead of the i5? I know it cost's £70 more but would allow me to keep the selected motherboard that I like. Or would it just be better to stick with the i5 and go with the bundle?!?
What??? (Beep) Wrong!
Dg said it right.
This^
You must make top money predicting the future![]()
