Hi all,
I was reading the thread on 10 fans connected to mobo (http://forums.overclockers.co.uk/showthread.php?t=18713287) and saw the OP's configuration images. This got me thinking.
I'm at work, so not able to upload pictures of current set up, but have mocked up a few quick images in excel of my current and proposed upgrades.
Here is the current configuration:
[/URL][/IMG]
This has been giving me acceptable temps on circe 50c on the CPU under gaming load and circa 55c on the GPU (with the GPU noctua fan on 100%) If I run it at 75% I get around 60c.
The revisions I am considering are as follows:
[/URL][/IMG]
Here the CPU rad fans are moving to push/pull, all case fans upgraded to Noctua 120mm/140mm.
The notable change is on the GPU that will be changed to the 2000rpm industrial Noctua's in push pull. I was also wondering whether it may be a possibility to bring the air into the case to help with the cooling under load....
My case is an Enthoo Luxe with both of the two removable bays taken out. Air flow should be pretty decent from the front/bottom, but I am aware that the position of the GPU in PCIE lane 1 (and the top 5.25 inch bay) act as natural barriers between air coming in from the front/bottom and reaching the top rear of the case.
I'm not using a fan controller right now, but have a Sata powered 5 PWN splitter for the case fans that are on the CPU opt header. The CPU header is used for the CPU rad fans (when this moves to push/pull it will likely use a SATA powered splitter for the 4 fans). The two AIO pumps are on system headers running at 100% and the GPU rad fan is on a system header. I have this manually set to 50% when not gaming and up the rpms in MSI command centre when I'm implementing my AB overclock profile for gaming.
I appreciate that airflow is really a science of trial and error with the specific set up etc, but am I making a stupid mistake to change the GPU rad fan air direction?
As always, any other suggestions are welcome for alternative solutions to improve flow and efficiency.
