hi
moving from a CM690iii case to a new corsair air 540 case. i have a simple loop:
whats he easiest way to drain it? suck it through the reservoir filling hole into a bucket?
started reading some youtube vids but none seemed to fit my predicament.
also, i want to add a draining valve to it. what one should get, my wc loop is a ocuk value 240mm kit.
is t easier to replace with a round standing pump and res in the main part of the 540?
also, can i place the xspc res vertically in the vertical 5.25 bay of the air case?
