Quick AIO Cooler Recommendation, Please?
1 Jun 2014
Howdy! I'm looking for a single 120mm AIO cooler recommendation.
It will be cooling a 6700K. I'll be overcolcking as much as the cooler allows, but top priorities are quiet performance and reliable build quality. I can replace the stock fan with a Gentle Typhoon if needs be, so really just looking for something with a good, quiet pump. No RGB bling or extras needed either. Also, I'm not in the UK, so you can recommend stuff not carried by OcUK if you think they're worth looking at.
Thanks in advance!
NZXT Kraken X41 would be great. i have the X61 and it does a great job for me. If you google it you'd be able to find some reveiws and comparisons.
+1 very good coolers.
the Corsair link crap is becoming a joke and just making there cooler a pain to run.
The x41 is a 140mm rad AIO though. In terms of single 120mm, the Corsair Hydro H80i GT is probably the best CLC at the moment.
If you prioritise silence then the Corsair CLC's are definitely not recommended. They can cool good but they need high pressure/rpm fans to do so and with that comes a lot of noise. For silence with good performance you would be much better off getting a good air cooler like the Notcua D15 or if you want some kind of AIO then the Swiftech H140-X/220-X/240-X are great if you can get them in your country. Check this detailed review for better explanation
Cheers. Already looked at the Swiftechs but unfortunately I only have a 120mm space on my case, which is too small to accommodate a large air cooler. Thanks for the suggestion though!
