How do i set up my computer? I dont want to mess it up.
11 Jan 2016
Nottingham
This is my build
1 x Cooler Master Hyper 212 Evo "Ultra High Performance, 4 Direct Contact Heat Pipes, Universal CPU Cooler" Black Fan @ 24.89GBP
1 x 850W Corsair RM Series 80PLUS Gold Modular Power Supply @ 108.98GBP
1 x Intel Core i5-6600K 3.50GHz (Skylake) Socket LGA1151 Processor @ 179.94GBP
1 x G.SKILL Ripjaws V Series DDR4 2400MHz 8GB(4GBx2) Memory Kit For Skylake @ 40.69GBP
1 x 1TB Samsung 850 EVO 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive - MZ-75E1T0BW/EU @ 229.98GBP
MSI NVIDIA GTX 970 Gaming Twin Frozr HDMI DVI-I DP Graphics Card (4GB, PCI Express, DDR5, 256 Bit)
Corsair CC-9011052-WW Carbide Series SPEC-03 Mid-Tower ATX Gaming Case with Red LED Fan - Black
Asus Z170-A Motherboards
Also people are telling me i need more SSD? Should i go about buying more? Cheers
the 2tb drive would probably be useful for storing media files etc, then you can use all the ssd for programs.
Ignore him a 1TB SSD is plenty of space for OS/Programs/Games, if you find you need more storage for Pictures/Music/Movies etc just chuck in the 2TB HDD you have.
CPU/Heatsink requires thermal paste, if buying the retail cpu SKU the heatsink already has this attached, although it never hurts to have a spare tube lying around, in case you need to reseat the heatsink or clean it.
Edit: To Clarify, the cooler master should come with some, but get some of your own. When buying the intel retail cpu package, the thermal paste is attached to the heatsink and not moveable. Overclockers seems to be recommending the Thermal Grizzly brand at the mo.
Honestly you really don't need an 850w psu for that build,If it were me I would go with a
https://www.overclockers.co.uk/supe...us-platinum-power-supply-black-ca-041-sf.html
Still a bit more than you need but a much better quality psu and a bit cheaper at that. For the money you would save on the psu you could get a https://www.overclockers.co.uk/phanteks-ph-tc12dx-cpu-cooler-black-hs-012-pt.html
So for around the same money or less you're getting a better psu and better cooler.
A 1tb ssd is plenty, however for that money and if possible I personally would run x2 500gb ssd's in raid if they cost around the same.But ultimately if you choose the 1tb ssd and keep the 2tb mechanical drive for music,movies etc you will have more than you need.
Yeah already bought it all dude,
It's worth watching.
Where abouts in Nottingham are you? I could come and help you out, if don't mind picking me up. Not busy, so any time is convenient.
Thatd be brilliant mate, but to be honest i spose i better do it my self so i know in future, im going to work my way up to a beasting PC,
