- 24 Aug 2005
- Uranus
Op what games do you play? On my 980 ti at 3440x1440 i get around 70-100fps depending on the game with ultra settings.
In your shoes I would get a 980ti only as an upgrade (otherwise you are wasting money and time on a sidegrade) then look at getting a 2600k/2700k/3770k (ivy runs hotter remember and may need to be delided to get to high overclocks) and overclock it to 4ghz-4.5ghz (which is an easy overclock on Sandybridge cpus, mine will do 4.8ghz on not much more than the stock volts, on stock it did over 4ghz from what I remember when messing with it. I just have 2 profiles setup in the bios 1 stock which it lives at 99.99% of of its life and then for FSX set to 4.8ghz profile.
Would a processor upgrade really make much difference? I asked this question a few months ago when considering grabbing a 2600k on the MM and the consensus was that it wouldn't really be noticeable as I'm bottlenecked by my graphics (in Afterburner none of the cores go above ~60% utilisation).
Anyway, had a go at overclocking last night - it's <almost> stable at +120 core / +440 mem, but I was getting driver crashes after running Heaven a few times in a row, it was getting late by that point so I didn't have time to finish tweaking it.
Is it worth bumping the voltage up a bit to try and get it stable (temps weren't getting above 70) or just keep dropping the overclock?
I haven't done any overclocking in about 10 years, so not sure on the resilience of components these days!![]()
I got bored whilst replying to this thread last night, my mate was doing some Project Cars laps, thought a potato quality video to demonstrate my surround setup was the answer!
The quality is crap (despite it being a 2.1Gb file on my phone!) - the brightness is too high on the video, it looks a lot better in the flesh...
I run my 2600k at stock for regular games and don't see it causing any issues for games that are GPU bottle necked but when I use some CPU dependent games like FSX then I overclock to 4.8ghz. But if you have a 2500 I would just buy a 980ti and try it, I'm guessing you may see a minor loss in frame rates compared to a overclocked 2600k, but the 2600k helps with games like BF4 as it uses hyper threading, apart from a few games that take advantage of that I wouldn't worry about it and just get a 980ti and enjoy your system until you can save up for a cpu upgrade later or spot a cheap one on the MM.
Just try +100 on the core and +250 on the mem and see if it runs stably. That will give you a decent enough boost![]()
That's kinda what I figured - I'll probably just wait till Pascal/Polaris to upgrade properly
No luck, even with the settings above, it wont get through the Heaven benchmark more than twice in a row.
I even tried it at half that; +50 core/+125 mem and bumped the mv to +37 (max it will go). No temperature problems, it doesn't go above 72c, but on the 3rd run through the benchmark (or if I just leave the demo running for ~15 mins) my screen just goes black and I have to hard-reset the system; event log shows the driver stopped responding.
With Maxwell cards try using as little volts as you can when overclocking. They really don't like extra heat and volts.
My GTX 980 Ti's don't like any extra volts and will crash if they go over 55c but are monster overclockers.
PS: Heaven is not the optimal solution if you want to test GPU stability during overclock. Can run without a problem, but same settings will spell trouble in different games.![]()
a 980ti is what you should be looking at not a 390.
