** PHANTEKS ENTHOO PRO M - ACRYLIC SIDE WINDOW EDITION ENABLED **
Any ETA on these yet as my new watercooling gear is due the end of the week & I want a new case to put it all in!
I may order the standard windowed one for now & hope the Overclockers stock just the full side window at a later date.
Mines arrived.
Only had a quick look at it so far & not going to be building my new setup for a week or so as still waiting for watercooling parts from EK to arrive.
Case looks good, well made & some nice little touches thoughout the case, but I'm not 100% convinced with the screw fittings for the window & side panel.
Time will tell however, as I'm just used to the quick release ones on my 650D
Full build log to follow once parts are here. :D
My case arrives tomorrow.
I've seen these types are fittings on side panels before. They are a little weird, but you'll get use to them. I won't be opening my case everyday (Mostly for cleaning) so I should be fine.
Just got home, turns out the parcel was delivered when the person who was supposed to be home had gone out temporarily! Luckily they left it with a neighbour.
Just gotta go round and pick it up now, they didn't answer the door when I tried on the way in! :(
