So I've decided the time has come to change my MX-5 and one of these has really caught my eye. Specifically this one.
http://www.autotrader.co.uk/classified/advert/201601210283417
Is there anything particular people can recommend I look out for when viewing? I know the mileage on this one is particularly high but both the mot history and service history look excellent on this one. I've found that they can sometimes let water in through failed door seals and they have a habit of eating coil packs, but both of these are quick and cheap fixed. I also know it likely needs a cambelt / waterpump change (i need to check when it was last done but some are recommending every 60-70k miles so it could just be due a second, even if this adds £400 to the purchase cost that's one I'm ok with.
MPG / Tax / Insurance are all comparable to my MX-5 so I'm not too worried about any of those.
Has anyone owned one and have any particular recommendations or advice about the model in question? I'm also open to suggestions of alternatives to look at, but it needs to be no more than £4500 and of a similar performance caliber to this model.
Thanks,
Thanks,
