Permabanned
- 8 Jan 2010
- UK
Now made official
http://gaming.logitech.com/en-gb/product/g900-chaos-spectrum-mouse
New mouse from Logitech. Nothing official yet so take specs with a pinch of salt.
Weight: 107G
DPI: 200~12000 which indicates a pmw3366.
1ms latency
TECHNICAL SPECIFICATION
Tracking
Resolution: 200 – 12,000 dpi
Max. acceleration: >40G*
Max. speed: >300 ips*
* Tested on Logitech G240 Gaming Mouse Pad
Responsiveness
USB data format: 16 bits/axis
USB report rate: 1000 Hz (1ms)
Wireless report rate: 1000Hz (1ms)
Wireless technology: Custom 2.4GHz
Microprocessor: 32-bit ARM
Glide
Dynamic coefficient of friction:* 0.11 ? (k)*
Static coefficient of friction:* 0.17 ? (s)*
*Tested on wood-veneer desktop
Durability
Buttons (Left / Right): 20 million clicks
Feet: 250 kilometers
Battery Life
Default lighting: 24 hours
No lighting: 32 hours
MOUSE SPECIFICATIONS
Connection Type: Wired/Wireless
USB Protocol: USB 2.0
DPI (Min/Max): 200-12,000
USB Report Rate: 1ms
Sensor: PMW3366
Indicator Lights (LED): Yes, RGB
Buttons: 6-11
Other Features
Hyperfast scroll wheel, on-the-fly DPS adjustment, up to 5 onboard profiles
Physical specifications
Height: 130 mm (5.12 in)
Width: 67 mm (2.64 in)
Depth: 40 mm (1.57 in)
Weight: 107 g (3.80 oz ) mouse only
Cable Length (Power/Charging): 1.83 M (6 ft)
Weight: 107G
1ms latency
