Looking for some sort of an understanding. As far as I know, wired transmission is to do with electrons and frequency modulation, either a digital peak(1) or trough(0) is enough to build up a system of data.
I think wireless is is to do with Photons and the Photo-electric effect. Is wireless data still sent in packets, if so how, is there an equivalent to wired frequency modulation. If it is then there must also be a constant stream of packets being sent, for example if you were to capture someone's wifi using a packet sniffer then there must be multiple of the same packet sent as the both you and the router your sniffing packets to both receive the packet.
Can anybody shed any light on the process of wireless transmission, be as technical as you like. How to send Photons as either 1 or 0, is there a constant stream of packets sent and if so how, which physical route do photons take, i.e are they sent in a certain direction and just find a path from A to B through the atmosphere etc.
