Caporegime
- 13 May 2003
- Warwickshire
Hi all...
My SV has hit 10k miles and is due a few service jobs. The chain is rusting for a start?! I also need to be able to clean the chain properly once I've replaced it, rather than rolling it back and forth on its side stand
Then there's various jobs I'd like to do like fixing the heated grips, replacing brake pads and hoses, replace exhaust, tail tidy, oil change, filter, plugs, etc...
My commute will also be getting a bit longer soon, so I need to make sure I keep up the maintenance.
So anyway, what type of maintenance stand do I need and what's recommended please?
Cheers louts.
Cheers louts.
