Switch between triple screen and single?
6 Jan 2013
Rollergirl
If I had 3*1080 24" screens and 1*ROG Swift... Could I plug all 4 into my 980Ti and switch between triple screen and single screen depending on what game I'm playing? Is that even possible?
I'm pretty sure you should be able to do that manually in the Nvidia control panel each time you load a new game. I'm not on my computer now, so can't check which settings you'd have to change, but it would just be a bit of an annoyance having to tinker with your multi-display settings and enabling/disabling screens is all.
As long as I didn't have to pull cables out I'd be happy. I could connect the Swift with a DisplayPort cable, but the other 3?
1*HDMI
1*DVI-HDMI
1*DP-HDMI
Would that work?
