Right guys, a few progress pics for you, unfortunately due to the awkwardness in the loft I was unable to take a pic of the bit of timber but basically used some 5x2 cut to 560mm and put this in between the joists.
Using some standard wood screws and washers the mount was securely fastened to the ceiling and will not be going anywhere quickly!:
I then went on to wall mount the speakers, remember this is having to double up as a guest room also hence the positioning (cables are only temporary until I decide where the AMP and eventual media player will live in the room, rears havn't been connected up):
Would rude to not show off the projector:
Plans are to paint the room a dark(ish) grey to help with the reflections and hoping the wife will let me paint the size of the screen wall white.
It is never going to be 100% as I need to make it a guest room also, will work with what I have and so far very happy with the results.
