Corsair H60i Screws
25 Jul 2009
England
Hi there,
I have a corsair h60i with a fan on one side. I have some AF120's and want one on each side.
What are the measurements of the screws I need or should I just use 2 screws on each side (currently have 4)
Thanks in advance
2 screws on each side would work for me.
how ever fan screws are 25mm long normally, as a standard fan is 20mm
re the noise problems, wouldn't you be better with SP120s than AF120s for a radiator?
Yeah, ile be ordering them soon. Bought the AFs because I need case fans anyway and wasn't sure if it was the h60i fan that was noisy anyway. The more I look into it, it appears it is probably the pump.
the SP fans are stupidly loud and have to run fast to actually move air, the is so many fans that are so much better for rads. what is the fin arrangement like on the h60i
