- 9 Jun 2015
Dear all,
I'm planning to buy a i76700k but am wondering what cooling solution to go for. I don't want something massive fitted on the motherboard so I considered watercooling but am a bit spooked by leakage horror stories I've seen around. What do you think?
I'm considering the following:
Antec H600 Kuhler 120mm
Antec H1200 Kuhler 240mm
Or any Corsair alternative?
As an alternative to watercooling, what air cooling would you recommend?
I'm not into massive OC, I'd like to push the 17 a little bit, but I wouldn't like a massive cooler as I want to keep the case compact and small.
