- 23 Sep 2009
- London
Hi,
I have an EK-FC580 GTX+ Plexi+EN (Nickel) waterblock that is showing signs of corrosion, there is a bronze colour in my WC loop and in my XSPC Dual D5 Bay Res as well as corrosion in the micro chambers of the GPU block.
I thought the 'EN' designation meant that these were built with the 'superior nickel plating and corrosion resistance'. Has anyone else experienced this issue since the newer nickel plating method?
I should also mention I have EK Motherboard blocks and a EP Supremaxy HF, these are all copper plated and whilst they show residue, it looks like it originated from the GPU block.
Can I just clean the block up and reuse it while I wait for Pascal or should I replace the block completely?
 ...concerned it'll eat away the seal around the pump or the acrylic glue though :/ but it'll be clean!
