Maybe I'm confused but the lowest point in your system is the bottom rad, so if the drainport isn't there you'll never get all the water out. Sorry if I'm mistaken.
yeah it would be tricky with how you have it set up, but that is the problem with the Enthoo and using the bottom rad space. Probably the reason why I've not done it myself yet.![]()
If your keeping it there have you tried putting your case on it's side with the drain pipe hanging down?
Sorry to be blunt.....but you are making this more complicated than it is.
You will not drain any water out of the loop that is BELOW your drain port. That bottom rad will never drain without:
- Suction
- Siphon action
- Changing orientation so that drain port is lower
It's that simple.
Best case scenario is that the bottom rad has 4 ports, 2 of which are on the bottom side (as viewed), on one of which you can add a drain port to. Without that, you will need to add a drain port to the bottom rad and orient the case 90 degrees so that said drain port is the lowest point.
Actually, the OP can, just a bit more complicated then he'd like to be.
The majority of the fluid can be drained by repeatingly inverted the case and so the bottom rad can have its water flow across and out of the draining valve
Yup, that's changing the orientation to move the drain port location. Looking at that tubing run though, it's going to be an absolute nightmare to manhandle that case in such a way to get the coolant out.
- Suction
- Siphon action
It's that simple.
Without that, you will need to add a drain port to the bottom rad and orient the case 90 degrees so that said drain port is the lowest point.Best case scenario is that the bottom rad has 4 ports, 2 of which are on the bottom side (as viewed), on one of which you can add a drain port to.
