Last week I heard a rattle coming from underneath the car, thinking it was either the heat shield or the exhaust had come loose took it to another local garage to get sorted as the one i usually use was closed for some reason.
They later phoned me up saying the front driver side spring had snapped and needed replacing.
Pick car up yesterday everything seemed fine at first rattle had gone, but while getting onto the main road, I noticed the steering was way off & there is some kind of knocking/rubbing sound coming from where they replaced the spring, it actually feels kinda dangerous to drive now.
Going ring the Garage up as soon as it opens but have a feeling they might fob me off saying the car fine, or try to charge me more for other suspension faults that suddenly appear.
Never had dealing like this before so not sure how to go about it.
