Does anyone got a good starting point settings for a t300rs? I've googled some but they are all quite old from older patch and tried it seems alright but was hoping for improvements.
In the TM profiler, I set everything at 100%, with spring at zero and effects from game. Some say to have the gain at around 65-80% or so fwiw.
In AC, I set gain to 100% (again, others recommend 60-80), with min force 2%, filter 0% and Kerb/Road/Slip at 80/60/50.
Then it's just a case of adjusting in game ffb to suit if required.
I do use a 320mm rim and like a beefy feel, so you may want to turn certain things down if running stock.
Also check out the ffbclip app available on race dept.
Does anyone know how to get a "minorating" (
www.minorating.com)? I've Googled it and just cannot work out how to get an A/B/C rating so that I can join servers that have a minorating requirement in place.
Hoping Uncle_Petey knows
I just got AJ to set up a server and we ran some laps to get the rating up.
We should have at least one or two with MR online now. Not sure of the rating required and can't check due to my internet playing up today...
ED: Turns out our Bathurst server is ABC.
If you just type ABCN in the server search box, you'll find a bunch of servers that you can join to run some laps and get your rating up.
