Rule of thumb, unless it makes you make a face when smelling it, it's all good.
is it still pinky red in colour or has it turned to a dark rouge, bordering on brown? If the latter, bin it.
Why bin it if it is turning brown? All red meat goes brown after oxidisation, so it's pretty normal. If it smells bad then bin it, but if it isn't pink or red, and smells like beef should it's absolutely perfect. These days we're far too cautious when it comes to raw red meat. It's borderline wasteful.
Those have been recently cut/mincedNot worth being ill for the sake of a few pounds, is it?
On the brown bit, why does it then stay pinky red on the butchers counter which is open to air.
When freshly slaughtered meat is cut into steaks, the muscle tissue comes into contact with oxygen in the air.
The myoglobin in the meat binds this oxygen, forming oxymyoglobin and giving the meat a red color.
However, if fresh meat sits for a period of time, generally over the course of several days, the structure of the myoglobin changes. The iron molecule in the middle is oxidized from its ferrous to ferric form and a different complex is formed called metmyoglobin. This compound turns the raw meat a brown color.
The meat is usually still safe to eat when cooked, but the brown, unappealing color turns off most consumers.
To avoid having your fresh meat turn brown, use it as soon as possible after purchasing it
Okay doke, still wont eat it.
But learned something new
Bold = that's me![]()
