Ah okay, I'll just assume my temp is okay as I don't over-clock.
Thanks
Your card doesn't have any pcie inputs so I doubt you'd have much temp coming from the VRM's on your card.
Meanwhile the 290 has 2 8-pin inputs so you can imagine the amount of juice it's sucking in.
Different developer though, even though they're all under the Ubisoft roof.
