Been looking at master socket as the wall has been re-plastered.
Before I start spending money and potentially get in trouble or see no improvement, I wanted to get some advice on old master socket and internal wiring replacement.
Used to get full 8,128kbps synchronization on ADSL max, and now with switch to ADSL2 I currently get between 22,000-23,000 kbps. Would be nice to max it as I'm close to exchange. Have tried two different modem routers using different chipsets; Broadcom and Texas Instrument (not the best for ADSL2 but achieved same speed).
The master socket is old, as the logo is a circled T using two dots for the right hand part of the T. Which Wikipedia lists as 1981-91 design.
Have an ADSL Nation faceplate (just over 10 years old) and using a hanging style filter made no difference.
Cable from pole goes to a block terminal box, which connects to white cable that feeds to an old BT logo master socket (circa 1980 to 1991 era logo). Not sure if white cable is CW1308 (found that name mentioned on a different thread here).
Cable from pole
Block terminal box
Block terminal box internal
Internal white cables from block terminal to master socket, and extension from master socket to secondary phone socket (currently not connected at master socket)
Rear of master socket
Front of master socket with ADSL Nation plate removed and filter connected
Cable from pole
Block terminal box
