I've just got a new hybrid card to use with the G1 gaming in SLI. Also a new motherboard, RAM and PSU (see signature).
When I boot up the pc and I use bios the CPU temperature is about 23C and the fans are generally not that loud.
Then I went into windows and launched MSI Afterburner to check on the GPU temps and the fans immediately kicked in from the afterburner profile and GPU 1 temp was 90C!
I immediately shutdown the pc and after letting it cool down I re-seated the two graphics cards and checked that the power connectors from the psu were plugged in properly.
I tried again and the temps for GPU1, which is the hybrid, were really high again with the fans on full blast. GPU2 temps were only 27C which increased to about 37C - fans 0%.
I tried the Hybrid on it's own and the temp was 50 straight away with the fan on high trying to keep at 60.
The back of the pc didn't feel that hot and I could feel cool air coming out of radiator exhaust.
I wonder if I have installed the radiator incorrectly or if there is an airflow problem because I have replaced the rear chassis exhaust fan with the radiator from the hybrid. The tubes going from the card to the radiator are a quite twisted which could be affecting the cooling.
I'd like to install the radiator above the HDD bays where the optical drives go but I don't know how to mount it. You can't do it with just the screws + washers provided.
I've got photos of the pc that I'd like to post on here. Can anyone recommend a good site to upload them to?
