Budget nVIDIA card for about £50 - which one?
I think bang for buck at this end of the budget has to be second hand AMD really.
While this seems to be the case, all the ones I've seen that are 50 or less are the 7700 series or a 6850.
Right now if I thought there was any point I could get a 6850 for £35, but it's only 1gb and worse than the 750 in benches.
I recon if the op can find a 270 or the 7850 version for 50-60 they will be his best option.
