I'm fed up with the cheap and nasty ones I bought off the bay a few years back. They are OK for multi-stranded cable I suppose, but I use 1.0mm or 1.5mm Single core lighting cable for my HC. The screws on the plugs stick out & the plastic covers either wont go back on.
I've been looking around & Consensus is Nakamanchi/Sewell/Voso look to be OK.
Anyone here own said makes and are they suitable for solid single core cable. I dont really want to rewire my HC TBH for the sake of a dozen Banana plugs thanks.
Agreed on the quality of his stuff.
