Nobody should be buying this. Microsoft need to be told that their business practices regarding "PC Gaming" aren't acceptable. You lot buying this are just as bad as the people who preorder games. Stop giving these people your money until they've earned it!!!
So windows store means no sli/cf right?
What about gsync/freesync?
Do we get access to the other 3 games as well if we buy this? I'm tempted but I dont know if I can justify it TBH
Ah so G-sync does work then that is good to hear might get this at some point then![]()
crossplatform with a common denominator "xbox", so much for having a 2-3k$ rig to have the same as the 300$ one, and yey for DX12...
Partial fix to my FS 1 fps issue. Start/close the game in windowed mode, once the game is all loaded up, alt+enter and full screen works as it should, have to keep dipping into windowed mode for any cut scenes however. Still not sure whats causing it, but besides this the game runs pretty well.
If we took that stance PC gaming would be dead as no one would buy anything.
I genuinely don't see what the issue is. I buy the game on WS, I have an account, as I have windows 10. The game downloaded and installed fine. I get asked to create a gamertag on my first launch of the game, it hasn't bothered me since. I know we all have quite a bit of mental anguish from the GFWL days but this genuinely seems painless, at this point its no better/worse then steam/origin/uplay.
DX12 means its down to the developer to implement mgpu. Only on a single card so can't comment - if it helps though, the driver profile for the game shows no SLI bits in nvinspector.
Gsync works as intended in both full screen and windowed
My frame rates are 50-70 outside, 80-100 inside, stock 980Ti, 4770K @ 4.6ghz, 16GB 2400mhz DDR3 running at 2560x1440 with maximum settings.
What tool are you using to measure the fps on a store exclusive?
Using the frame monitor that comes with geforce experience
Share>Preferences>Overlay>FPS Counter.
Sure, they have DX12 listed as supported so lets see![]()
For those that asked, unless I'm missing something, Dxtory does not work with Gears.
