Caporegime
- 8 Jan 2004
- Rutland
Personally I wouldn't buy 500mbps adaptors without gigabit ports. Worth the extra.
The powerlines are a single collision domain so only one of the homeplugs can transmit at any one time. Is like a wireless network or an old network hub. The entire network can do 500mbit wether you have two homeplugs or three or four. Still max speed is 500mbit shared theoretical speed. Why its not worth them putting gigabit ports on. Would only be worth it for a point to point link.
Doesn't make sense to me, I have 4 homeplugs and easily exceed 100mbit speeds in my day to day use.
The tp link article explains it better. Just saying the best speed your ever going to get even with gigabit ports for av500 is 240mbit. Once you start adding more adapters the available bandwidth stays the same but is now shared between all adapters in the network. That's under perfect conditions. Once you put it in real world conditions the 240mbits figure will probably go down even further.
Have you had a look to see if the manual has a section on setting up the security as I do believe they can sometimes on a rare occasion pick up the other signal from a neighbour but you should be able to stop it.
Just ordered a couple of the TP-Links with passthrough... plenty of Haribo please![]()
Old wifi: ~ 11ms ping / 26meg download.
New powerlines: 7ms ping / 54meg download.
My internet is 50meg virgin, so can't complain
(also got some Haribo, cheers!)
Id love these as I'm a floor above the router but the electric circuits in my house are a bit different, so won't allow for it to work. I don't know it works, but been told it just "doesn't"
