It will be the safest ride in the World now
Would be interesting to see how many people feel like yourself vs how many won't go near the thing.
I would not suprised to see that they may have fitted some sort of "bumper" system to the top of each train near the rail so that if a car ever hit another there would be a safe distance between passengers and the rear of the car in front? Half a foot of steel pole with a big rubber bung!
Then again it depends on the design of the train cars and weight etc etc
From what I have read if it locks out again there are physical keyed locks at locations around the track that need to be re-set manually forcing the engineer to go to the blocked part of the track. I have no idea if this is true or not just what was posted on a coaster forum.....
Human factors as it's finest. See a situation which you don't understand.. assume the best "it'll be alright" or deny the existence of a problem and carry on regardless.
Terrible incident which was easily avoidable![]()
Completely agree, it should be standard practice across the board that you should not be allowed to override the system which would have prevented this in the first place.
If the ride needs to be stopped manually then cut all power, not oh let's just ignore the warning system and override it.
Some safety systems are designed to isolate the power (interlocking guards etc) whereas others can be put in to an "engineer" or "test" mode, which disables guards but allows the equipment to function.
This type of engineering mode is typically used in production equipment which needs to be operating for faults to be detected i.e. diagnosis of electrical faults in automated robots. Now, this could well be the case (that the ride was overridden) because they were testing it, but their process sucks major *** if they didn't complete a visual inspection of the track before pushing that button.
Part of me hopes they'll (courts) consider the owner of the ride to be Merlin Attractions Ltd (parent group of Alton Towers Resort), as the new sentencing guidelines take in to account organisational profit and the fine will be much larger.
