- 30 Sep 2005
Hi all,
One for the ios devs among us.
My client requires the following custom app being built, and I'd like to know if it's technically possible.
The app is very simple. You click on the icon to launch and see the following
Username
Password
Login
The user enters their username and password and the credentials go to the wifi settings and connects them to an SSID. It then takes the same credentials and logs them into onedrive.
Once the user has finished, they go back into the app where the login button has changed to logout. They click it and it removes their credentials ready for the next user.
There is an installation of cisco meraki on site which I believe can deploy custom apps.
Thanks
Username
Password
Login
Thanks
