I'm looking for either a separate DAC and separate headphone amp or a combination of the two - which ever is better value.
I currently use the headphone amp on my motherboard. The Asus Maximus Hero VIII has a ESS ES9023P DAC and 2Vrms headphone amp. I'm not sure how this would compare to an external amp in my price range.
Looking for the best music quality but will also use the headphones for games and films.
A question about headphone amps in general.
How are they usually connected to the source?
Can I connect a headphone amp to my AVR and then switch between different inputs on the AVR? (pc,wiiu,blu-ray player and tv set top box connected with HDMI).
My AVR (Denon AVR-X2200W) has USB ports on it but I don't know if you can output audio through them.
If the amp will only work when it is connected directly to the pc that would be ok because that's what I use for all music and the majority of other media but it would be nice to have everything connected to the amp.
Also, where do people try out headphones, amps and other audio equipment? I assume some shops will let you try stuff.
Certainly confused myself seeing as there's effectively three european websites.
