Permabanned
- 15 Apr 2010
Hi guys,
I've just installed a new cooler (Swiftech H240X2 Prestige).
All seemed to go well, but when I booted up I get error code 55 displayed on my Asus mobo's Q-code display.
After some investigation I've found that if there is a RAM DIMM installed in either of the 2 slots closest (in any configuration) to the CPU it will error code and refuse to POST.
A single DIMM in either of the two further away slots, and the system boots perfectly.
After removing the cooler to check if I'd damaged the CPU or socket pins (which it I couldn't see any evidence of), I found damage to the surface of the motherboard underneath one of the cooler mounting screws.
Has the cooler damaged my board?
